The profile pic in the center is missing the steel rails they are a bit shorter than the extrusion.
A friend gave me a couple of these rails. I want to upgrade the fence on my table saw to make a single-axis CNC. But I can't figure out the brand. I want to buy a locking slide. The steel rails are 0.250" dia. The overall width is 1.675"
I have attached three photos.
I have done extensive searching online. Without any luck.
Thanks for any help you can give.
Do you see the attachments?
https://photos.google.com/photo/AF1Q...x8JsDosoYAX1We
https://photos.google.com/photo/AF1Q...EmVwCI8eW0jvGL
https://photos.google.com/photo/AF1Q...mcg-CMoBBXjbi-
Did this work?
Try again, no photos at all. Google links don't work.
Jim Dawson
Sandy, Oregon, USA
Try what? The attachment didn't work. I see the photos that I attached. They are at the bottom of the original post labeled Attached thumbnails.
https://photos.app.goo.gl/arcykdtbsEVEHj698
https://photos.app.goo.gl/Ax6QrDze88HSfQucA
https://photos.app.goo.gl/DCvnJt3ofmpdHnUJ9
What about links to google photos? Probably not if other google links didn't work.
If attachments and urls don't work what should I do?
I don't see an FAQ of this.
you can remove the spaces
h t t p s :/ /photos. app. goo. gl / arcykdtbsEVEHj698
h t t p s :/ /photos. app. goo. gl / Ax6QrDze88HSfQucA
h t t p s :/ /photos. app. goo. gl / DCvnJt3ofmpdHnUJ9
I don't know what else to do.
OK, now the Google links are working.
Sorry, I have never seen rails like that.
Jim Dawson
Sandy, Oregon, USA
You may not like this, but using Google as a photo host is a problem, and not just at CNCZone. Unlike some other photo hosts, Google wants to (this is my characterization of the process, not Google's) determine the permissions that the viewer may have to see the photos before Google will display them. From Google's perspective its a 'privacy' issue. From a user perspective, its a giant PITA. My solution: use a different photo host. If you'd like a recomendation, I use https://postimages.org/ and have been pleased how it works.
I have noticed some earlier occasional issues with attachments not being displayed/available. This forum is running on a 10 year old version of vBulletin. I understand that there is a forum software upgrade in the works. I don't have specifics, but am hopeful that a variety of issues will get resolved.
