This should give you what you need, just select the type of timing pulley profile, metric/ inch, number of teeth and ratio, or a desired center distance.
https://sdp-si.com/tools/center-distance-designer.php
Hows it going guys,
Anyone have any good resources on timing belts ? I would like to design a 2:1 gear system with HTD belts but having a hard time figuring out relationship between belt circumference and pulley distance. Is there a rule of thumb or something.
Thanks !
Mactec54
Thanks !
