What size rails? A block that long is probably meant to be the only block on the rail, and may have two tracks of bearings per race, or just a much longer loop.
Hi all!
My current machine's Y-axis saddle length is 137.5mm. The new linear guideway I'm installing on my machine comes with 124mm bearing blocks.
The load-bearing specs of the new bearing block are more than enough to support the weight on my current Y-axis.
Can I use only 1 bearing block to mount the saddle on?
