I will build a plastic injection machine and need a ball screw that is used to press a plate that is attached to a rod that presses in the plastic. I need a bearing in a housing that is attached to the end of the ball screw and the plate that can push or pull the plate.
Does anyone here know standard parts that i can use? A 80mm ball screw with 20mm lead will work with my project.
Thanks!
