Counterfeit angular bearings - ebay
Results 1 to 4 of 4
Thread: Counterfeit angular bearings - ebay
    Jul 2005
    ECUADOR
    Default Counterfeit angular bearings - ebay
    Recently I purchased 4 bearings for a cincinnati arrow ballscrew support. Each pair were purchase in EBAY from different vendors and the 4 bearings are counterfeit. DON'T BUY PRESICION BEARINGS ON EBAY.
    I realized the bearings are counterfeit because the QR CODE in each box only give you the code model and if you download the application from NSK or WBA they will tell you if they are counterfeit / original and it will give you a web page with the real measuring values for each specific bearing.
    Also I measured the high of the bearings and didn't correspond to the values on the box.
    Be careful and don't waste money on Ebay.
    Attached Thumbnails Attached Thumbnails Counterfeit angular bearings - ebay-whatsapp-image-2021-04-28-17-22-a   Counterfeit angular bearings - ebay-whatsapp-image-2021-04-28-17-22-a   Counterfeit angular bearings - ebay-whatsapp-image-2021-04-28-17-22-a   Counterfeit angular bearings - ebay-whatsapp-image-2021-04-28-17-22-a
    Jan 2018
    United Kingdom
    Default Re: Counterfeit angular bearings - ebay
    Quote Originally Posted by Chivo View Post
    'Precision' stuff on ebay. You're having a laugh!. Not a chance!
    Member mactec54's Avatar
    Jan 2005
    There is no way you could get an accurate measurement with what you are using
    There is nothing wrong with your Bearings if they are the correct type for the job you are going to use them for, these special high Precision Bearings are spec for the manufacture that they where acquired from and sold on eBay there number and code will not be to the normal spec's from the supplier, most of these Bearing are custom for the customer that was using them, I have brought many of these Bearings from eBay and they are the real thing and normally a great deal
    If they are the correct Contact Angle for your Ballscrews, just have to install them correctly and they will be fine, don't install them if they are the wrong Contact Angle
    Never take these Bearings out of the Packet until they are ready to be installed
    Mactec54
    Jan 2005
    Quote Originally Posted by dazp1976 View Post
    It's there if you no what you are looking at
    Mactec54
