I have an old 3 phase 90w induction motor. Can't remember what it came off. But it's got a twisted pinion shaft that I expect goes into a reduction gearbox.
I want to use it for a drive on a machine but don't have a gearbox just a pinion shaft.
Question. Is there a pulley or sprocket that is available for a shaft like this? I've had a pretty good look on the net and can't seem to find anything. My only other alternative is to make something custom. It doesn't need to be perfect or hold a lot of torque. Just drive.
Anyone have a suggestion or know about these?
Sent from my SM-N970F using Tapatalk
That is the pinion gear built into the motor shaft. There is no stock component that will convert directly to a pulley type drive. A clamp type drive coupling should grab onto the shaft, you are just going to have to build something.
Jim Dawson
Sandy, Oregon, USA
Hi Jim is that a fact. Ok. I will make something for it. I did see a split sprocket actually that looked like a solution. Off the motor its high rpm low torque required.
Cheers
