Problem Harmonic drive knocking noise
Results 1 to 5 of 5
Thread: Harmonic drive knocking noise
    Member NORDLE's Avatar
    Sep 2016
    RUNECK
    Default Harmonic drive knocking noise
    https://youtu.be/XhlZheT1fu0
    Hello, i recently got a 4th Axis harmonic drive for my diy mill. It works totaly fine but makes some strange knocking noise when spinning in one direction (clock wise @12sec in the video).
    Is this something to worry about?
    Dec 2013
    Default Re: Harmonic drive knocking noise
    It sounds more electronic than mechanical. Like the stepper motor is skipping a beat or something. I would remove the stepper from the unit and see if the same thing occurs. Then rotate the harmonic drive by hand and maybe you can feel something. Maybe put a shaft in an electric drill to rotate the harmonic drive to check for a mechanical problem.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2006
    If you've had the drive apart, check to be sure the flex spline isn't off-center. If the spline is installed correctly where it only contacts the circular spline 180* apart. If the flex spline is even 1 spline off, you will get contact between non-engaged spline tips on one half of the circumference, so you'll get knocking/tapping in one direction as the splines snap over each other.
    Sep 2016
    RUNECK
    Today i tried to spin my drive by hand couldn't hear any knocking tough. Also wen spun by the stepper the knocking seems to just went away. All it makes now is a gentle grinding noise, its a bit uneven tough. Does not sound too bad, but as i have no previous experience with harmonic drives dunno if thats normal?
    Mar 2006
    Check through this.
    I suspect your problem is covered on page 35 out of 57.
    https://www.harmonicdrive.net/_hd/co..._Component.pdf
