Anyone? I did find my small Powermatic grease gun that I "think" will fit the Hiwin zerks.
Thank you,
dan
What grease/lube would you recommend fort LG20's on a vertical Z? I'm in the US and machine wood, MDF so oil dripping would be a big proglem.
Thank you,
dan
Thank you,
dan
Mobilux EP1
UCCNC 2017 Screenset
Most Hiwin rails are lubed with white lithium grease, initially - but I don't know what they use inside the bearing itself.
https://www.hiwin.com/pdf/lubricating_instructions.pdf
You can use anything that isn't moly or graphite. They bung up the tiny balls and stuff the bearing.
I wipe down with lithium, but if you are going to use the nipple, lithium is probably not the stuff for a grease gun.
Mobilux is good for woodworking environments - it doesn't allow the dust to migrate too much.
In case it helps anyone in the future, I bought the Mobilux but was still having a lot of trouble feeding the Hiwin's zerks. I bought the clamp-on quick-release connector and now have zero leaks.
Anyone have an idea on how many pumps to give the LG20's? I don't see an overfill port.
Thank you,
dan
