Newbie Ball screw maintenance
Results 1 to 4 of 4
Thread: Ball screw maintenance
    Nov 2016
    United Kingdom
    Default Ball screw maintenance
    Hi there,
    I have a second hand cnc machine that I'd like to do some maintenance on. I've read that the ball screw needs greasing routinely. I have these ts1610 nuts that I can't any info on (the closest I've found are sfu1610 ball screws).
    There are 3 holes on the side of the mounting flange- 2 small and 1 large. I'm guess the large one is where the grease will enter (see pic 2 below)? It's an m5 thread so I was going to buy a few m5 grease nipples along with a grease gun. Can anyone tell me if this is a good assumption?
    Does anyone know what the 2 smaller holes are for (see pic 3 below)?
    Finally, could anyone tell me which grease to use? I'm going to spray white lithium grease on the screw threads itself. Shall I get a pot of this and pack it inside the nut too?
    cheers guys,
    Nic
    Ball screw maintenance-pic-1-jpgBall screw maintenance-pic-2-jpgBall screw maintenance-pic-3-jpg
    Attached Thumbnails Attached Thumbnails Ball screw maintenance-pic-1-jpg   Ball screw maintenance-pic-2-jpg   Ball screw maintenance-pic-3-jpg
    Dec 2003
    Default Re: Ball screw maintenance
    Generally machines that have a waylube system in place also lube the ball screws at the same time, Vactra 2 etc way lube etc.
    Nov 2016
    United Kingdom
    great thanks for the quick response.
    so something like this?
    https://www.ebay.co.uk/itm/1L-Mobil-...AAAOSw2SNe~gma
    Do i just drip feed it into the threaded hole then on the side of the ball screw nut?
    Dec 2003
    That should do it!
