CW/CCW is relative to the end you are referencing.
i.e. Driving/Operating on.
I have bought many of these ballscrews in the past but I didn’t care about their rotation since they all were for CNC application where you can change the rotation thru a software.
But I want to buy some for a manual lathe project I’m working on now. I have one left over from my CNC projects but when I turn it CW the ballscrew moves towards me which is the wrong way.
Can you order these screws in CW or CCW rotation and how do you specify it. I don’t know if the Chinese know the difference of CW / CCW and I want to make sure I will get what I order.
Nicolas
You are right Al, in the attached picture at the right it should be the driving end (I will assume) since that’s the end where the motor normally will connect.
I’m referring at that end and asking if the ballscrew is considered CW/CCW looking at it from that end.
In any case, can you order these ballscrews CW or CCW and how you specify it? Just ask for CW or CCW?
To me when I turn the ballscrew CW from the driving end the center mounting block should move away from you, but I could be wrong
Nicolas
Here is one from Hiwin they are all different in how there spec's are this is just (1 ) example this is showing Right Hand
Mactec54
Thank you mastec54 for the heads up. I forgot that we also call the rotation LH / RH but would LH = CCW and RH=CW? This way I can make sure the Chinese understand what I want.
Nicolas
Screws are not spec'd as CW or CCW. They are either RH or LH.
UCCNC 2017 Screenset
I will do so mastec54, thanks again
Nicolas
In the past I have obtained mine from HiWin, they are excellent quality, out of Taiwan.
They come with a thread quality resolution test chart
A machinist I knew machined the ends for me, he had to use ceramic tooling they were so hard.
I used to buy mine from Mr. Chai at eBay.com (linearmotionbearings) who has good reviews in this forum. Mr. Chai used to send them out for machining the ends to my specs and I was getting them ready to use.
Do you have the link for HiWin?
Nicolas
That was a while ago, someone on ebay used to bring them in by the dozen at a time and sell individually, I don't have the link any more.
