Lubrication for Hobby CNC Machine
Results 1 to 4 of 4
Thread: Lubrication for Hobby CNC Machine
    Member Project_Hopeless's Avatar
    Feb 2019
    Sterling Heights Michigan
    Question Lubrication for Hobby CNC Machine
    I have a DIY CNC router sporting 1605 ball screws, SBR16 round linear rails, and HGR15 profile rails. I would like to use a single grease for all of these if possible.
    This is not a high speed machine and not in continuous use.
    So after some research I'm looking at Mobilith SHC 220 grease. Is this a good choice? Should I go perhaps lower viscosity SHC 100? Or some other product?
    Mar 2003
    Shelby Township
    Default Re: Lubrication for Hobby CNC Machine
    Mobilux EP1 is cheap, and readily available. It's listed in the Hiwin Lubrication manual.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Feb 2019
    Quote Originally Posted by ger21 View Post
    Ah perfect.
    https://www.hiwin.com/pdf/lubricating_instructions.pdf
    For some reason some of my research steered me away from EP greases.
    Got to trust the manufacturer in this case.
    Thx!
    Apr 2015
    I have always understood that EP or hypoid oils should never be used in gearboxes that used bronze or brass components because the additives can react badly with these metals, I assume this is true of greases as well. Dave
