16mm Pillow block on 5/8 Thomson rails
Results 1 to 2 of 2
Thread: 16mm Pillow block on 5/8 Thomson rails
    Jun 2007
    Default 16mm Pillow block on 5/8 Thomson rails
    I have a set of two beautiful 5/8 (.625") Thomson hardened steel rails 3 feet long. They would normally use the SPB10-opn linear bearings, which are quite expensive. I have found 16mm open bearings online which is .629" for significantly less cost. Do you think this would be suitable on a metal cutting CNC mill build? My gut says yes, but I would like to hear from other experts. I can purchase these 16mm in either steel circulating ball bearing or a hard polymer. The polymer is more expensive. I am unsure which is best or if it is even an option.
    I already have one metal cutting CNC machine with the proper bearings, but I'm thinking of building another with my extra rails.
    Thanks.
    Nov 2013
    Default Re: 16mm Pillow block on 5/8 Thomson rails
    using 16mm bearings on 5/8 rails will result in lash, a definite no-no in CNC.
    Are theses rails round? End mounted round rails are way to flexible for a mill. Square rails bolted every 2-4 inches to an absolutely rigid
    bed is required for metal cutting machines.
    Craig
