has anyone used a cylinder slide for guide rails?
Results 1 to 2 of 2
Thread: has anyone used a cylinder slide for guide rails?
    Member Snowfox222's Avatar
    Feb 2020
    Question has anyone used a cylinder slide for guide rails?
    i found a business out my way that deals in reselling liquidated industrial goods. one of the things i keep finding are these pneumatic slide cylinders, and i cant help but wonder if they are even worth looking at as far as cnc gantry is concerned. it also helps that every time i find one they are almost always dirt cheap. now im not looking to keep the air part working, i just want the slide of it. i'm figuring if i just remove the end caps and away she goes. i posted a picture of the one i'm thinking about so you guys know what i'm talking about
    am i completely way off base here, or is this a tree worth barking up? my current machine is a genmitsu 3018 so any amount of rigidity is more than i have now and probably more accurate.
    Attached Thumbnails Attached Thumbnails has anyone used a cylinder slide for guide rails?-20200107074229443_l-jpg
    Jan 2005
    Default Re: has anyone used a cylinder slide for guide rails?
    Quote Originally Posted by Snowfox222 View Post
    They are used on a lot of commercial Router for different stations for Drilling Etc some are used for multi spindle machines also, they don't normally have much travel, so not that useful
    Mactec54
