Not sure whether you are means the thread length,
For 2005/2010 ball screw which with end machining for BK15/BF15,the standard end machining length for both is 78mm,that means if the total length is 1000mm,then the thread length between BK15/BF15 is 1000-76=924mm.
Generally the supplier can make customize length production according your design.
