Greetings!
Everyone has always been very helpful here.
Its been awhile. I need to build this 24x24" y axis. Think large size 3D printer for printing clay. See photo. My base is 3/4" Melamine, I have 2 20mm linear slides with 4 Bearing blocks, I will run a Small Nema 23 with 22 tooth Pulleys. I have on order HTD3M 15mm wide belt.
My rails don't have mounting holes.
The Bearing slides have 4 6mm mounting holes. I need to have springs, so I can Tram the bed.
So, I was going to run a homemade bearing idler on one side and the Nema 23 with 22 tooth pulley on the other.
I would appreciate any thought?
I have some separate parts I'm working on I will discuss in other posts.
Thanks!!!
Max
- Finished 3-Axis CNC build, benchmarking advice?
- Problem- Struggling to complete the build..need pro advice/help: Shaking problem (linear axis)
- New Machine Build- 2nd Build, 50"x110" Steel Base, Aluminum Gantry, possible 4th axis
- New Machine Build- 5' x 12' x 16" 5 Axis Router Build
- First build: 5-axis. Could use some advice!
This is an ongoing project. There are several old threads on my build. This is Custom. the other parts are 2-meter Z and X axis. This is an add on to make it Cartesian for testing.
Just wanted some thoughts on a Y axis approach. I have a couple days until my belt is in, so I'm trying to tie everything together.
The actual clay extruder is already built Nema 23 with a 20:1 Worm reducer.
Max
