Need Help! Holding brake needed on a 4/5th axis when using a harmonic drive? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Holding brake needed on a 4/5th axis when using a harmonic drive?
  1. #21
    Oct 2016
    Default Re: Holding brake needed on a 4/5th axis when using a harmonic drive?
    Quote Originally Posted by spumco View Post
    Will it work? Yep. And the OP, if this thing ever gets built, will work out what the actual limitations of using it are.
    Well...
    Pic is just after I poured the epoxy a couple days ago. It's starting to cool off here in Ohio so I hurried up and got the frame together so I could get the epoxy down before winter. Checked it today with my 36" straight edge and except for the weld seams where the epoxy is a little deeper and shrunk more, I couldn't get a 0.0015" feeler gauge to go so I am pretty happy. Gonna bring home my 0.0005" level home from work tomorrow and see where I'm at.
    I should really start a build log since this isn't really the right sub-forum for this.
  2. #22
    May 2016
    Did you say Ohio?
    Care to share what part?
  3. #23
    Oct 2016
    Lancaster
  4. #24
    May 2016
    Quote Originally Posted by shinji2k View Post
    Lancaster
    Ahh. Close, but not close enough to Ashtabula for a mid-week garage night.
  5. #25
    Oct 2016
    Yeah its a bit far to drive for, admittedly, not much to see.
