Timing pulley slipping on gearbox shaft
Results 1 to 11 of 11
Thread: Timing pulley slipping on gearbox shaft
    Activation process WilliamKinsey's Avatar
    Sep 2018
    Default Timing pulley slipping on gearbox shaft
    Im not certain this is the correct forum category for this question... if not, please recommend correct forum topic.
    I have a custom built CNC Hotwire machine with 2 animatics motors (x&y), Apex dynamics gear boxes connected to steel timing belt pulleys. The x pulley is slipping a little. Enough to make circles with opposing flat sides. The x gearbox shaft key is worn & The 2 set screws have worn into the shaft a little. I can still run machine but it’s off a little due to x axis timing pulley play on shaft. New gearbox is $1,100 min. Looking to attempt fix before buying new gearbox and pulley because it will probably wear new shaft again. Looking for a suggestion on the strongest locking type pulley on the shaft to avoid future slip & wear on shaft and pulley key slot. I.E. adding flat sides to shaft for set screws, adding more set screws on new pulley, custom fabricating a timing pulley onto taper bushing? Or other ideas. This is probably a common issue I’d imagine.
    Thanks Bill
    Attached Thumbnails Attached Thumbnails Timing pulley slipping on gearbox shaft-shaft-pulley-wear-jpg
    May 2015
    Default Re: Timing pulley slipping on gearbox shaft
    Hhy don't you just remove the setscrews one at a time and drill a hole in the shaft and replace?
    Rod Webster
    www.vmn.com.au
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Put loctite on the shaft and pulley.
    UCCNC 2017 Screenset
    Sep 2018
    Thx or idea. do you recommend the strongest Loctite? Could I still pull of the pulley later on with pulley puller?
    Sep 2018
    not sure if reply went thru. thanks for suggestion. I think that would help. I'll probably broach a new key slot in the pulley bore too. add a couple more set screws. and loctite everything.
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi William - I Only use loctite on my pulleys. No screws or keys. I use permanent grade loctite. If you ever need to get them off a little heat from a heat gun and they come off easily. But the plan is for them never to come off. Peter
    The Difference Between Red, Blue, Green and Purple Threadlockers - Henkel Adhesive Technologies Blog
  7. #7
    Mar 2003
    Shelby Township
    Quote Originally Posted by WilliamKinsey View Post
    Yes, I'd use red loctite. If you need to remove it later, heat it with a torch, and you'll be able to pull it off.
  8. #8
    Sep 2018
    Quote Originally Posted by ger21 View Post
    Thanks for info????
  9. #9
    Sep 2018
    Thank you for the recommendation. And link. Whatever I end up doing loctite will be involved.
  10. #10
    Sep 2005
    If you have a gap to fill as a worn shaft you might look at the Green Loctite, read the spec's before deciding.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  11. #11
    Aug 2010
    Thanks for input. ‘I’ll check out green loctite
