Advice on Bearing for 24" Rotary Table?
Results 1 to 5 of 5
Thread: Advice on Bearing for 24" Rotary Table?
    Activation process disneytoy2's Avatar
    Nov 2018
    Default Advice on Bearing for 24" Rotary Table?
    Hello!
    I'm working on a project that will have a 24" diameter steel plate that need to rotate smoothly. Can someone suggest some options regarding bearings? Prefer not crazy expensive. I've looked at some axial bearings.There will be around 100-150lb on top.
    Randy
    PS This will be a horizontal table. Like a turntable.
    Dec 2013
    Default Re: Advice on Bearing for 24" Rotary Table?
    How about a heavy truck tapered wheel bearing, normally the inner bearings are pretty large.
    A little less accurate but cheap https://www.vxb.com/1000-lbs-Capacit...-p/kit8999.htm
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2018
    I was thinking automotive. Thanks, I'll check that out.
    Nov 2018
    Jim, taking your advice I went with a Dodge RAM 3500 wheel hub assembly (new), on ebay for $30 shipped.:-) it's a bit stiff but plenty rigid. Thanks
    I may buy a rotor to use as a mounting plate.
    Dec 2013
    Happy the hear it will work for you. $30 is a heck of a deal. It will loosen up after a few hundred miles
    Jim Dawson
    Sandy, Oregon, USA
