Need Help! need help in assembling a rotating nut
Results 1 to 9 of 9
Thread: need help in assembling a rotating nut
    Aug 2013
    Question need help in assembling a rotating nut
    I need help designing a strap driven nut that would stay fix but the leadscrew would translate trough the pulley driven by the strap.
    Attached Thumbnails Attached Thumbnails need help in assembling a rotating nut-image-1-jpg
    Dec 2013
    Default Re: need help in assembling a rotating nut
    Here is how I did one
    Built a housing
    need help in assembling a rotating nut-img_1266-jpg
    and put roller bearings in it to fit the nut body
    need help in assembling a rotating nut-img_1277-jpg
    Machined the pulley and put 4 drive pin holes in it that fit the nut bolt pattern
    need help in assembling a rotating nut-img_1276-jpg
    And the way it fits together
    need help in assembling a rotating nut-img_1278-jpg
    and the ''exploded'' assembly, note the thrust bearings on each side of the nut/pulley assembly.
    need help in assembling a rotating nut-img_1279-jpg
    The preload on the thrust bearings is adjusted by these 4 set screws in the motor mount plate
    need help in assembling a rotating nut-img_1281-jpg
    And the assembled view. The little roller ''car'' keeps the lead screw from rotating in use.
    need help in assembling a rotating nut-img_1288-jpg
    I hope this gives you some ideas.
    Attached Thumbnails Attached Thumbnails need help in assembling a rotating nut-img_1277-jpg   need help in assembling a rotating nut-img_1276-jpg   need help in assembling a rotating nut-img_1278-jpg   need help in assembling a rotating nut-img_1279-jpg
    need help in assembling a rotating nut-img_1281-jpg   need help in assembling a rotating nut-img_1288-jpg   need help in assembling a rotating nut-img_1266-jpg
    Jim Dawson
    Sandy, Oregon, USA
    Registered vegipete's Avatar
    Mar 2006
    Sol 3 (YVR)
    Nicely done, Jim. I take it that the O.D. of the nut runs happily on the roller bearings. Did the nut body need any work to match the roller bearings?
    Dec 2013
    Quote Originally Posted by vegipete View Post
    Thank you !
    Yes, the roller bearings are happy. I was lucky in that the OD of the nut was exactly the correct diameter to fit a standard roller bearing. I don't remember the exact dimension but it was around 60mm or so.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2013
    I already thanked you buti will do it again : you are an expert. I use your photos to figure out what to do and order bearings roller, stop and leadscrew.
    Aug 2013
    Quote Originally Posted by Jim Dawson View Post
    Thank you !
    i usually speak french not sure to understand "run happy". Does this mean not a press fit nor a slack fitting but just inserted in freely and turn supported all the way?
  7. #7
    Dec 2013
    Quote Originally Posted by jipilabont View Post
    Yes, It is U.S. slang meaning a good fit and and working well.
    Jim Dawson
    Sandy, Oregon, USA
  8. #8
    Aug 2013
    So a 28mm nut would run happy in a bearing of 30mm. Or may be with shims?
  9. #9
    Dec 2013
    No, you would want a 28mm bearing. The nut needs to fit the bearing with <0.025mm clearance. Should be a tight slip fit.
    Metric Needle Bearing
    Jim Dawson
    Sandy, Oregon, USA
