really
NO one knows if a 2005 or 2010 ball screw will whip at 60inchs on a rigid machnine 2500 max rpm?
I have had my cnc for years. it is 26 by 32 inches
do the 2010 ballscrews seem about right?
if so 2005 or 2010
i want to build a larger format
1500mm by 1500 mm
I was thinking about 2010 for the 1500mm
the basic square framework and gantry will be 80/20 3060
with 1545 cross members
it should be pretty rigid.
use for cutting uhmw, other plastics, wood, some aluminum.
servos
are
(3 Max)
Part Number Frame Size
(NEMA)Length
(inches)Peak Torque
(oz-in)Cont.(RMS) Trq
(oz-in)Peak Power
(W)Cont. Power
(W)Rated Speed
(RPM)Max Speed
(RPM)
PM-SDSK-3411 34 3.14 638 150.2 219.90 201.10 2010 2320
really
For a router, you want at least 10mm pitch screws.
If you really need 25m/min speeds, then get 2525 ballscrews, and gear the motor 2:1. I would not try spinning 2010 screws at 2500rpm.
UCCNC 2017 Screenset
I'm only looking for 300 to 350 Rapids. Most my cutting is inches
Sent from my SM-G955U using Tapatalk
