- Co2 laser problem, electrical discharge sound, too much power.
Hey. I hope this is the right section.
I bought a second "red and black" 130w co2 laser. First one is running fine, all good.
The second one - At some times I hear electric cracking noise, discharge somewhere near tube.
The first machine does perfectly engrave at 150mm/s and 9% power (mat finish, perfect).
The second machine even on 500mm/s and 9% power does engrave at least 0.5mm deep.
Both machines are supposed to be identical..
Any suggestions appreciated. Thank you in advance.
Re: Co2 laser problem, electrical discharge sound, too much power.
Update: So, cracking noise gone by itself and there is a little switch on tube PSU which enables power control.
- You may not post replies
- You may not edit your posts
Forum Rules
