- To CO2 laser experts
Re: To CO2 laser experts
Most likely the tube is junk. Every CO2 tube consists of an inner tube with power connections and gas. Then an outer jacket where the water circulates. So your mixing water and high voltage and placing the tube in a metal box not designed to see water.
Assuming the outer jacket water side is all thats damaged, is it worth taking the chance it will spring a leak at some point. It’s complete junk if the inner tube is damaged. Tubes aren’t that expensive.
If the tube came with broke IN or OUT water glass pipe it is easy to fix with UV adhesive or even epoxy, but in your case no way, u can use as decorative in your workshop.
buy a RECI tube & move on.
If your CO2 laser Beam contour is not sealed now and lost all CO2 - than your tube is junk now.
If it have only damaged HV mounting pad - use good high temperature epoxy without metal.
- You may not post replies
- You may not edit your posts
Forum Rules
