- looking for replacement laser
Bought this inexpensive laser engraver a few years ago and has done a good job putting small logos on wooden objects .but pretty sure the laser is toast. I bought another more powerful one and it is working fine but was wondering if there are replacements for these cheapies. Unfortunately I cannot remember how strong this laser was and there are no markings at all. My new one is 15 watt and can do metal and stone and my old one could only do wood so must have been under 10 watt. Is it worth the effort or is it a throwaway? Thanks for any tips or suggestions.
Re: looking for replacement laser
Well, took a chance on a part at Banggood. Could not confirm whether amps, wattage volts match up but it works. Had to lengthen the wire and ream out the hole in the cooling block on the gantry. Still fiddling with the settings but seems I need to double the laser intensity setting.
https://usa.banggood.com/1000mw-Blui...r_warehouse=CN
- You may not post replies
- You may not edit your posts
Forum Rules
