- How to wire THC controller (SF-HC25C3) to Sherman Cutter-70.
Recently I bought CNC portable plasma cutter with SF-HC25C3 THC controller ( I attached specification) and I would like to wire it to my plasam cutter which haven't got any plug dedicated to connect THC. There is Arc+ and Arc- output in specification but the question is how and specifically where to connect it?
specification: https://megawrzuta.pl/download/90380...4f03aae18.html
Thanks for the amazing insight
Re: How to wire THC controller (SF-HC25C3) to Sherman Cutter-70.
Hi Bro,
I have the same hardware but I don't know how to correct wire the plasma unit with the TCH. can you please give me some guidance.
Thanks in advance
Borta
- You may not post replies
- You may not edit your posts
Forum Rules
