Laser arcing on annode connection
Results 1 to 1 of 1
Thread: Laser arcing on annode connection
    Member pacguy's Avatar
    Jul 2019
    Default Laser arcing on annode connection
    Hello,
    I am fairly new to this and have been trying to setup a 40w laser on a greenbull cnc. I'm extremely new to this and was unable to find a lot of good documentation so have been struggling to get this to work for weeks. I have it setup correctly and can get it to test fire with no issue when I press the test button on the power supply and am now working to get it to fire using the cnc usb software. I could not get it to work so I used the test fire button to make sure the laser was still active and accidentally shocked myself.
    When this happened I pulled the high tension line loose without realizing it and did a few more test fires over the next 30 minutes with no issue. Then I started seeing the arcing on the video and smelling smoke. I realized the line was not attached to the power supply so I reconnected it and now I can't get the laser to fire at all. Have I ruined the tube or is this something that can be fixed?
    As far as I can tell the line is still connected securely to the terminal and I removed the old tape and added some more.
    The control board is a mk1 board from buildyourcnc.com
    arcing:
    laser tube: https://buildyourcnc.com/item/Laser-...ube-CO2-40Watt
    power supply: https://buildyourcnc.com/item/Laser-...Supply-CO2-40W
    I am really struggling with this and would appreciate any help.
    Attached Thumbnails Attached Thumbnails Laser arcing on annode connection-img_20191008_182815-jpg   Laser arcing on annode connection-img_20191008_183126-jpg   Laser arcing on annode connection-img_20191008_183114-jpg   Laser arcing on annode connection-usbcontrollerrev1datasheet-jpg
    Laser arcing on annode connection-0szxcv6-jpg
