- Power Supply for 80W laser
I am in need of a power supply for an 80W Hurricane Lasers Hugo. Hurricane is now gone of course but I believe it is a G. Weike made machine. At any rate I would like to know if anyone might know what power supply is used as I would like to find one that is a drop in fit. The machine is currently packed into a very tight room and I am unable to open up the side door far enough to get a good look at the power supply in order to find a number. I will disconnect the machine and pull it out of the room if I have to but it's a giant headache for me as I am disabled. So if anyone might have, or know where to find, the information I would be most appreciative.
Kind regards and thanks for your time!
Chad Veich
cwveich@cwvmodels.com
- You may not post replies
- You may not edit your posts
Forum Rules
