Need Help! Gravograph LS800 help
Results 1 to 1 of 1
Thread: Gravograph LS800 help
    Member Mbachus's Avatar
    Jun 2024
    Default Gravograph LS800 help
    Gravograph LS800 control panel not powering up. I can hear the fans come on, but the control panel will not come on. The contol panel is loose. My question is, is there a pressure switch in the control panel that has to make contact to power up? Has anyone had this same problem with the control panel not powering up?
    withinlights's Avatar
    Jun 2024
    Default Re: Gravograph LS800 help
    It sounds like the loose control panel might be the issue. First, power off and unplug the machine for safety. Check the connections between the control panel and the main unit; a loose or disconnected cable could be the cause. Tighten any loose screws or connections securing the control panel. There isn't typically a pressure switch that needs to make contact for it to power up, but ensuring all connections are secure might resolve the issue.
