New to laser engraving
Results 1 to 8 of 8
Thread: New to laser engraving
    Member Scoutdawg's Avatar
    Jan 2024
    Default New to laser engraving
    Hello all. I just picked up an older Mercury L-25 laser engraver. I have never used one of these machines or anything like this before. I'm starting brand new. I want to know if I can even run this equipment with a laptop or if I need a desktop for it. I am just wondering where I should start. I want to use this for wood and plastics. Thank you for any and all directions on what my first steps should be.
    Sent from my SM-N986U using Tapatalk
    Nov 2008
    Default Re: New to laser engraving
    Look into Lightburn software
    Jan 2024
    Thanks for the heads up on light burn. From what I have researched it seems to be the best. Does anyone have the drivers I could download?
    Nov 2008
    I’m not familiar with your machine. I’m assuming it’s CO2.
    Normally you don’t need drivers. Lightburn outputs in the format of your controller. You either load the controller using a memory stick or upload the file to the controller directly using your Wi-Fi. The latter is more complicated to set up, but worth it.
    Lightburn has an extensive user forum that is very active. Way more active then this forum.
    Jan 2024
    It is an older cO2 machine. It originally had a desktop computer that would send the files through Autocad or Coreldraw. I will look for a light burn forum to check out. Gotta clean up the engraver this week
    Nov 2008
    It might be worth upgrading the controller if you can’t get it working. Unless you have those programs it’s not worth investing in one just to save that controller.
  7. #7
    Jan 2024
    Here are some pics of the machine.
  8. #8
    Frank356's Avatar
    Jan 2024
    I have tutorials on using LightBurn with other brands of AlgoLaser machines How To Laser Engrave Denim with LightBurn URL?https://algolaser.com/blogs/how-to/l...with-lightburn. I wonder if they can be helpful to you?
