I figured it out. I need to open EZCAD using "Run as Administrator" option. Now if I change something in the configuration screen, it's saved.
In EZCad 3 I'm trying to set the calibration file location. I hit F3, then in the calibration section I go to File and navigate to the NinePointCor.cor calibration file. The I close the dialog box. But when I close EZCad and re-open, my change is not saved. PC is running Windows 10.
"You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
