I too have this same problem, anyone have a solution?
Hello everyone, I am new to this forum and need to see if I can get some help. I was able to download the driver so my Ezcad2 is not in Demo mode. However, when trying to do just a simple shape to test out laser the laser will "red" button will work fine and outline the square but the "mark" will not work. There is a red light that say not ready on the bottom. When I try to press it to see if it will give me information on error issue but it does nothing. Has anyone encountered this and if so any suggestions? I appreciate any help, thank you.
I also have this problem, someone please help. I just spent way too much money on this damn laser for it to not work lol
OK, so I figured it out, go into System Parameters/Param, click Ports, change 'Door IO - Input Port' to NULL. Button should now show READY and will work
I followed the answer here and my door IO and input port are not the same as this any advice.
My buttons are input IO Mask Output IO Mask I changed them to null.
Is null mean zero is checked or is it all are unchecked. Thanks in advance
I got the same issue.After changing the IO setting, the problem is still there.
