Need Help! laser smashes into the sides SH-G570 Chinese
Results 1 to 1 of 1
Thread: laser smashes into the sides SH-G570 Chinese
    Member adeys's Avatar
    Oct 2021
    Default laser smashes into the sides SH-G570 Chinese
    im currently having alot of problems with a new laser
    to begin with it was ok but the direction was visa versa so i went into light burn and altered the polarity of them i forgot to back anything up now it just smashes into the side and doesn't stop unless i push the emergency button ive tried to restore to defaults but no password works only if i have rd works on if someone has a solution for this id be grateful
    thanks
    ade
    BluSystm's Avatar
    Oct 2021
    Default Re: laser smashes into the sides SH-G570 Chinese
    Hi Ade,
    If you use RDWorks, the 'Vendor settings' password is RD8888
    You should make polarity changes there and then 'write' it to the laser controller.
    Have you tried loading a different job file?
    What motherboard does your machine have?
    Oct 2021
    Yeah it does it all the time the board is a rudia thing is I mainly use light burn
    BluSystm's Avatar
    Oct 2021
    I also have a Ruida in my machine, RDC6445G(EC). I am thinking that since you made the changes in Lightburn, this will always be part of the files that you send to your machine, therefore you will always have the same results. Sounds like the changes need to be made in Lightburn to rectify this?
