- Stroke limit setup
Stroke limit setup
Hello everybody,
I have an LVD Impuls 4030 equipped with fanuc 16LB conttrol. I have just installed and I have a problem with the stroke limit of Z axis. The table is lower than it was in original installation and I must corrcet the stroke limit of Z axis. I entered the parameters and I enable the parameter enter bit. I try to change the Z stroke limit but when I press input it takes it for a moment and after it goes back to the old number. So it cannot hold the new parameter. It looks that another parameter does not allow me to change this parameters. I tried with other parameters and I can change. Only the stroke limit is not possible. Any idea about what to check?
- You may not post replies
- You may not edit your posts
Forum Rules
