- Now EzCad2 is discontinued is it time to investigate more into how it works ?
Since EzCad2 is discontinued and EzCad3 is a pretty expensive retrofit of software and control board (at least) might be time to poke over how it works more .
The XY2-100 for the galvo is easy enough, the Raycus 8 bit power + sync seems fairly straightforward since its tight timing either cpu+fpga/cpld+ram as a driver, or just keep figuring out the LMC1 interface. Maybe BJCZ will update/give out the EzCAD2 SDK instead.
Re: Now EzCad2 is discontinued is it time to investigate more into how it works ?
Is anyone out there using EzCad3?
Cheers.
Bill.
- You may not post replies
- You may not edit your posts
Forum Rules
