Setting bed size...
Results 1 to 4 of 4
Thread: Setting bed size...
    Member randell13's Avatar
    Sep 2020
    Default Setting bed size...
    Hey all, my machine doesnt seem to know where it is and hits the side and makes an awful noise. How do I set up / caliberable the bed so the machine knows where it is? Im using GRBL for laser software
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Default Re: Setting bed size...
    Do you have home switches/sensors?
    Which G-code sender are you using (GRBL is just a software that resides in arduino).
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Sep 2020
    thanks for the reply. I am not using switches/sensors and I am using Lightburn to send to the machine. Really keen to try and get this figured out so I can start using the machine and also then try and tackle the router part!
    Thanks again
    Apr 2005
    Vanuatu
    Obviously LightBurn does not know where your laser head is.
    I do nit use LB but there are a lot of videos on YT showing how to set LB to work with any machine.
    You should not use Homing routine if you do not have home switches installed.
    I guess that there should be an option to strat your job from actual position.
Setting bed size...
Setting bed size...
Setting bed size...
