New Machine Build New Build Questions
Results 1 to 6 of 6
Thread: New Build Questions
    Feb 2005
    Question New Build Questions
    Ok So I have probably gone about this the wrong way but :0 I'm new to lasers.
    I have bought a chinese 100W tube and Power Supply.
    I want to use Mach 3 as I am use this software for my laser. Plan to do engraving and cutting (Model Aircraft Parts). Will mach3 be suitable for what I want to do?
    How do you suggest getting the laser to fire with Mach3? Im sure for the parts it wont be an issue to just use the spindle but not sure about the engraving on/off speeds.
    Is there a controller (BOB) I should be looking at which will run the g-code as it comes either way I decide to run it. I'm on a budget.
    Suggestions would be appreciated.
    Prboz
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Cool Re: New Build Questions
    On what kind of machine you're going to place the tube?
    Mach3 is bad when it comes to control laser. I can suggest you to use GRBL (on Arduino platform) as motion controller when dealing with lasers.
    On machine that I use I have a router () and 2.5W laser module. Routing-cutting-engraving is controlled with Mach3, when it comes to laser, I just swap BOB with GRBL and use different software (LaserGRBL) or LightBurn.
    LaserGRBL:
    Mach3:
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Feb 2005
    Default Re: New Build Questions
    I'm actually making a machine from scratch.
    Apr 2005
    Vanuatu
    As I wrote, no mather is it is machine built from scratch or you intend to modify the existing one, I would not recommend Mach3/4
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Here's some info on controlling a laser with Mach3.
    http://tweakie.byethost10.com/27_files/Page652.htm
    UCCNC 2017 Screenset
    Nov 2013
    Mach3 was developed before laser operations were commonplace amongst hobbyists and given that all development of Mach3 ceased six years ago the prospect
    of Mach3 being a good control solution for laser operations is poor.
    Mach4 is a very much newer and developing software solution.It has some specialised instructions for laser operations and the Ethernet SmoothStepper has realtime
    laser vectoring/rastering features. My understanding, from others, who have used the combination report good results.
    Craig
New Build Questions
New Build Questions
