30watt fiber laser Chinese and Ezcad2
Results 1 to 4 of 4
Thread: 30watt fiber laser Chinese and Ezcad2
    Stevenb856's Avatar
    Jan 2020
    Default 30watt fiber laser Chinese and Ezcad2
    Having issues resetting up the laser to work correctly after a windows 10 update last year. Manufacture is less then helpful. (no surprise there)
    1. 30watt chinese fiber laser with F-Theta F-330mm 1064nm len
    2. Board Model: LMCFIBER JXT-M40015 REV 20120321
    3. Ezcad2 software
    4. windows 10 32bit as I found out laser will not support the 64bit os.
    5. Will check all the solider joints as i'm still getting DOG message even with correct driver installed. (All of inside connectors are tight and joints are good in the welds)
    Other then that i have had this 6k unit on my desk for a year without being able to use it.
    I have the ability to remote someone in if there willing to give me a hand with this.
    Thank you,
    Steven
    Aug 2009
    Default Re: 30watt fiber laser Chinese and Ezcad2
    i'm using windows 10 x64 with EzCad2 2.14.11 , is it the drivers missing? i have the LMC4 Fiber + 60w raycus, and 110mm 185mm lense so can't help you with the cal much, i posted my settings just now on the other thread, but prob not much help.
    Member bamacustomguns's Avatar
    May 2020
    i am having same issue fiber laser windows 10 64 bit say demo mode
    Aug 2009
    demo mode means its not detecting the usb device, which likely means the drivers aren't installed, or 32 bit drivers on a 64 bit os.
