- Need Help!- Data Error on K1290L JQ Laser Powercut4311
First, I'm sorry I do not speak English very well
Second, I need your help !
I start in the world of CNCs. I bought a used laser cutter, K1290L from JQLaser.
The seller told me the software used for the machine, powercut 4311. Already, it was not easy to find.
Then the first one did not find my machine.
Then, finding another download and reinstalling the program from it, he recognized the machine.
Unfortunately, I can send the files to the machine, but when the job starts, it tells me Error Data.
I specify that even a job created directly in the software gives the same error code.
I think there is a problem with the software but I can not find others, and I do not find how to solve this problem ...
Ideas ? Did someone have the same worries?
The seller did not have this problem, and was unable to send me the exact software he was using.
I thought it could be a software version problem ...
If somebody can help me .... PPllleeeeeaaaaassssseee !
Angéline
Re: Data Error on K1290L JQ Laser Powercut4311
Probably a bad water flow sensor, or it is wired incorrectly.
Hi
I have exactly the same problem machine won't start after loading project and showing error data message.Got no clue how to solve this problem.Did you manage to sort it out if yes please let me know.Power Cut 4311.
- You may not post replies
- You may not edit your posts
Forum Rules
