Dual purpose CNC - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
Thread: Dual purpose CNC
  1. #13
    Mar 2003
    Shelby Township
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  2. #14
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Default Re: Dual purpose CNC
    If you want to use Arduino Nano, here are the files so that you can make an adapter board.
    The D-25 is feemale, as on your computer.
    Pinout is the same as for Mach3, Pin 1 is PWM!!
    All home/limit switches are NC.
    Dual purpose CNC-screenshot-2019-05-22-20-11-45-a
    GRBL-LPT-B_Cu.pdf
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  3. #15
    Feb 2005
    United Kingdom
    Quote Originally Posted by ericks View Post
    I was just looking at the laser you showed in the pic....endurance lasers make something similar but with the higher wattage (10W) units in these type of lasers they use heatsinks with peltier cooling.
    Thanks eriks, So it's similar. The one I have shown is 15Watt. Will the 10W version cut through 5mm Plywood. Do you have a manufacturers model or part number on your laser, where can I buy ?
  4. #16
    ericks
    Guest
    Quote Originally Posted by George View Post
    I did not buy one, was just doing a bit of research. The strongest they do is 10W. Best to visit their site, if you contact them they are very good at answering questions
    endurancelasers.com
  5. #17
    Jan 2005
    Quote Originally Posted by ZASto View Post
    GRBL-LPT-B_Cu.pdf
    You will need to verify that the pinout of this board is correct for the breakout board you are currently using. As far as "Being the same as Mach3", Mach 3 has software customizable pinouts so that cannot be guaranteed.
  6. #18
    Apr 2005
    Vanuatu
    Welll...
    I do use Mach3 and GRBL with a board that iI attached pic and pdf.
    I just switch LPT cable from computer to my adapter board.
    On the other end is 5 axis breakout board (of course, chineese made)
    OK, maybe I cheateed a little bit, I recompiled GRBL with a bit different pinout to be compatible with my BOB pinout.
    Anyway, dynamic laser power works like a charm, no overburn at edges.
    BTW the USB connector is for powering BOB (needs 5V.
Dual purpose CNC
Dual purpose CNC
Dual purpose CNC
