Need Help! Use co2 laser machine controll card to controll 30W fiber source
Results 1 to 1 of 1
Thread: Use co2 laser machine controll card to controll 30W fiber source
    Member oneeye's Avatar
    Aug 2005
    Brazil
    Default Use co2 laser machine controll card to controll 30W fiber source
    Hi all,
    i have two 30W fiber laser source from marking machines, IPG and Raycus , i want to install the fiber dource on a small co2 laser cutting machine. The machine use a Ph card, similar to Ruida . Have a way to controll the fiber source using this card? I need only to controll fire laser and power. Or maybe use the card to fire laser and something like analogic simple circuit to set power manually
    Jun 2015
    Latvia
    Ruida controller doesn’t allow to operate with galvo scan head. So you can’t.
    May 2020
    Default Re: Use co2 laser machine controll card to controll 30W fiber source
    Hi, EZCAD2 seems to be the best solution.
