- Problem- CorelLaser settings for rubber stamp engraving
I have a chinese 80W 40x60 laser machine. Recently I started engraving rubber stamp sheets, but when it comes to fine lines the problem begins, because the laser engraves at straight angles (90 degrees) thin lines are too weak and tend to break away with usage and aging. I've seen that Trotec software have a functionality for stamps to create a chamfer for that purpose, so when there is the need to reinforce the lines so they are no longer weak and prone to break. Is there any workaround for chinese machines to do that?. My machine came with Li Hui Yu Studio dongle, that means CorelLaser is my control software.
Thanks in advance.,
P.S.: https://www.troteclaser.com/en/knowl...amp-engraving/
Reason: Added link to Trotec functionality example
Re: CorelLaser settings for rubber stamp engraving
i have a laser machine like yours but i had to get it repaired
- You may not post replies
- You may not edit your posts
Forum Rules
