- Need Help!- Alternatives to PEPS Fabrication
Good afternoon,
My workplace purchased a CNC LASER-Cutting machine from Germany, from SiroLasertec.
The AC-300F. It is a 3000W LASER-Cutter.
I have no real issues with the LASER-cutter itself.
What I have issues with, however, is its CAM software, which is
PEPS Machining - ProBurn
My issues:
-No nesting support (without paying for it - my boss is looking into this)
-When it imports the linework (AutoCAD DXF), it doesn't seem to recognize what lines are the 'inner lines' (think , for example, about the circle inside a O or the triangle inside an A) intelligently.
-Better Toolpath generation from provided file.
Does anyone recommend something good? I am in the dark regarding other software.
- You may not post replies
- You may not edit your posts
Forum Rules
