- Need Help!- CorelLaser 2013.02 - Floating Point division by zero
*Registered User*
I have a 40 Watt Laser made in China. It came with a USB dongle so I can use the laser with CoreLaser.
I have installed the Corel 10 and I am using Windows 10 Version 1083
When I click on the Cut or Engrave button I get an error
"Floating point division by zero"
I click OK and it goes back to Corel
I have uninstalled both Corel 10 and CorelLaser and then re-installed. No change
I dug up an old laptop and installed it on it and works fine.
I have tried to contact the supplier and have no response.
I just got a similar laser and had the same error last night. Did you find a fix?
- You may not post replies
- You may not edit your posts
Forum Rules
