- Need Help!- laser firing when traveling to origin
Hi. I just change controllers and the laser is firing when traveling to its origin. It happens when I turn on the machine and when its finished cutting a job. It also wont fire at 21% but is full power at 22%. It did that with the last controller as well. Any ideas
\Thanks
Re: laser firing when traveling to origin
what controller are you using and software?
Hello,
I have seen this a few times...
The problem is much more likely to be in the logic portion of your laser power supply. The best and safest way to solve the problem is to replace the laser power supply.
It all depends on how the controller and laser power supply are wired... but you should confirm the wires from Laser-On are connected to theL pin of the power supply. Then make sure the software is configured for Low signal triggering.
Make sure the Analog signal is connected from the controller AN1 to the “IN” pin of the laser power supply.
Please take time to tell us what solved the problems.
Ray Scott
Rabbit Laser USA
- You may not post replies
- You may not edit your posts
Forum Rules
