Why is my RDWorks image Backwards?
Results 1 to 2 of 2
Thread: Why is my RDWorks image Backwards?
    Dec 2014
    Default Why is my RDWorks image Backwards?
    Just started using RDWorks and going by a lot of Goggling I haven't found the solution to these two problems
    1) I found that the Axis X Mirror shouldn't be checked but when I send the job to the Laser its Flipped on the X ( Backwards ) ( See Attached )
    2) Laser Head Position I have as Top Left but its hanging around the Top Right? ( See Attached )
    Attached Thumbnails Attached Thumbnails Why is my RDWorks image Backwards?-img_0434-jpg   Why is my RDWorks image Backwards?-img_0435-jpg
    Apr 2006
    Default Re: Why is my RDWorks image Backwards?
    The problem is with the ”Screen Origin”
    Press theZ/U button to go to the menu screen.
    Press the”Screen Origin” button to select that feature
    Press the Z/U button to change the screen view direction
    Press “enter” to keep the setting.
    Press “escape” to exit the menu.
    Ray Scott
    Rabbit Laser USA
