LASER Cutter Issue
Results 1 to 4 of 4
Thread: LASER Cutter Issue
    nickyminaj123's Avatar
    Jan 2018
    london
    Default LASER Cutter Issue
    I have a CNC, a 3D printer and a lathe. I work in automation, so I should be able to understand your lingo, within reason....
    what software do you get ? I read places where they mention Lasermate and some other Lasercut....Are we talking about the same product here ? Is this a software proprietary to Redsail or an independent product ? do you get a legit copy or a bootleg one ?
    I saw that some of you were talking about a dongle....Will I get one or am I going to run in demo mode, with tons of restrictions ?
    Anywhere I can download a demo version, to get familiar until I get my machine?
    Any idea?
    Please help.
    Thanks!
    I didn't find the right solution from the Internet.
    References
    http://www.cnczone.com
    Creative video studio
    Nov 2008
    Default Re: LASER Cutter Issue
    In this 1k to 3k price range laser cutter you normally find controllers designed for laser cutting and engraving. A cnc router or printer will vector cut but find it difficult to engrave. So custom controllers have custom software. You pay for the complete package. No need to steal anything because you can download it for free. All the software in this price range is similar. Different names but all work the same based on manuals I’ve seen.
    Without the controller downloading software would have no use
    Apr 2006
    Make sure to buy a laser machine that has a RuiDa controller and uses RDWorks. This requirement can keep you inside your target price range and also helps to ensure the rest of the laser isn’t the bottom level crap either.
    Ray Scott
    Rabbit Laser USA
    Member germanr's Avatar
    Aug 2018
    Buenos Aires
    Laser Cut is proprietary software used by the Leetro brand controllers.
    Some Chinese manufacturers use it in their laser cutting and engraving machines.
    As Ray mentioned, there are also controllers of the Ruida brand, which use the RDWork software.
    At BuchiCNC we have experience with the two brands of controllers.
    Leetro works well, but has fewer functions on the panel such as previewing on-screen designs and LaserCut software is much less friendly than RDWorks. As for the laser beam in my opinion, Leetro handle it better than Ruida.
    In addition Laser cut uses a dongle and RDWorks does not. Lasercut installs additional drivers so that the dongle works and in practice it is quite uncomfortable to have a USB port used by the dongle.
    If you want to download a trial version of each software to compare them you can do it from these links:
    LaserCut
    RDWorks V8
    Greetings and good luck
    German Rothar
    BuchiCNC USA
    You can check our CO2 laser cutters here:
    CO2 Laser cutting machines
    If you want a metal laser engraver:
    Laser metal engravers
    Great CNC Router:
    CNC Routers
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
LASER Cutter Issue
LASER Cutter Issue
