Cloudray Power supply permamently on full power.
Results 1 to 1 of 1
Thread: Cloudray Power supply permamently on full power.
    Feb 2005
    United Kingdom
    Default Cloudray Power supply permamently on full power.
    I need some help please.
    Why is my laser firing at full power regardless of the power setting in Lightburn and even when the Ruida is set to 0 power for both min and max power settings.
    I have checked all connection from Ruida to Laser power supply.
    The laser on signal switches high to low on command.
    I measure the PWM signals at the power supply (M80) 80Watt. have been tested at 25%,50% and 75% as you can see from my photos all are good.
    I made a test lead as per Cloudray and the psu out put full power regardless of the potentiomet settin. The switch did it's job and switche power on/off as required.
    I'm struggling now.
    I suspect my Power supply is ignoring the l on 1 signal. I have asked Cloudray for a warranty replacement but all I get is the same questions over and over.
    Mr Moderator. IF this is in the wrong forum would you kindly move it for me. Thanks
    Also I cannot seem to upload my pictures. I select the pics I want loaded from the 'manage Attachements' but once selected and shown on the list they refuse to upload!
    Also when I tried to save changes here i get 'not logged in message' when i try to log in again it directs me to ' Industry Arena '
    Attached Thumbnails Attached Thumbnails Cloudray Power supply permamently on full power.-25-jpg   Cloudray Power supply permamently on full power.-psu-tester-jpg   Cloudray Power supply permamently on full power.-75-jpg
