Need Help! Wiring a Laser to my CNC using an External 12V Power Supply
Results 1 to 4 of 4
Thread: Wiring a Laser to my CNC using an External 12V Power Supply
    Default Wiring a Laser to my CNC using an External 12V Power Supply
    Hi all... I've bought a laser to attach to my already operational CNC mill... As usual with Chinese parts the documentation is useless and doesn't cover any wiring info - leading me to search it out instead. Except I can't find exactly what I'm looking for - can someone confirm whether I have understood things right?
    I have a DB25-1205 breakout board. It has a 5v power supply only - not a 12v supply like my laser needs, neither does it have a relay. You can see it here:
    Wiring a Laser to my CNC using an External 12V Power Supply-db25-1205-board-jpg
    My Laser is a Sculpfun S9. It has a 3 pin connection on the controller board already that's mounted to it. The pins are '(12V+' 'GND' 'PWM')
    https://www.sculpfun3d.com/productinfo/720040.html
    Wiring a Laser to my CNC using an External 12V Power Supply-sculpfun-board-jpg
    Is my solution to simply connect both wires from a 12v power supply to the Vcc and GND pins above - then connect a single wire to the PWM pin and run that to one of the pins (pin 17 I understand) on my breakout board?
    If that is correct then I guess I can power on the laser by turning on the power supply - but it will be effectively off until the software sends a PWM signal to fire it up?... i.e by me running code or playing with the controls manually in Mach3
    I hope this makes sense... All advice appreciated ????
    Attached Thumbnails Attached Thumbnails Wiring a Laser to my CNC using an External 12V Power Supply-sculpfun-board-jpg   Wiring a Laser to my CNC using an External 12V Power Supply-db25-1205-board-jpg
    Default Re: Wiring a Laser to my CNC using an External 12V Power Supply
    OK so I have done a bit more research and think I was close but also need to run a wire from -12v GND on the laser back to GND on my BOB..... here is a basic sketch as I think it needs to be... is this right??
    Basically I'm concerned about connecting -12v to the GND on my BOB because everything else on it is -5V but I heard that a common GND is fine regardless and it's ok to mix-12v and -5v.
    Wiring a Laser to my CNC using an External 12V Power Supply-bob-wiring-idea-jpg
    Attached Thumbnails Attached Thumbnails Wiring a Laser to my CNC using an External 12V Power Supply-bob-wiring-idea-jpg
    Mar 2011
    Argentina
    Quote Originally Posted by dcrowder79 View Post
    Did it work?
    Jun 2005
    Your drawing looks correct that should work
