Greetings all -
I'm using a 100W laser with a Ruida 644XS controller and an unknown brand power supply. The machine will work great for a period of time and then will start an endless cycle of resetting or cutting partial jobs and then resetting.
I've checked all the connections everwhere and they are good. The only thing that I can come up with is a problem with ambient temperature. When it is colder (50-60 degrees), the machine falls into the reset cycle. When it is warmer, the machine works great.
Any suggestions from the pros out there? Am I on the right track or might there be another avenue to explore for a solution?
Thanks very much in advance,
Blake
