Choosing Co2 tube for DIY laser
Results 1 to 2 of 2
Thread: Choosing Co2 tube for DIY laser
    Member kapel's Avatar
    Sep 2019
    Default Choosing Co2 tube for DIY laser
    Hi guys.
    I'm building CO2 laser around 45W. I have all the component selected except laser tube. I could fir 100cm tube in my design but I would like to start with 80-85cm tube for a few months.
    I'll be cutting max 5mm plyboard and 5mm acrylic.
    My DIY design:
    I'm trying to decide between this two:
    Cloudray (noname) CR45:
    https://www.cloudraylaser.com/collec...12892224421939
    And
    Tongli TLC800-50
    https://www.cloudraylaser.com/collec...12816485711923
    I really appritiate any constructive comments and suggestions.
    BR,
    Frenky
    Attached Thumbnails Attached Thumbnails Choosing Co2 tube for DIY laser-laser111111-jpg
    Member KarlNychig's Avatar
    Oct 2019
    Default Re: Choosing Co2 tube for DIY laser
    Hello,
    I have also the same question. But it's for my second tube.
    I'm hesitating between those 2 tubes:
    https://www.aliexpress.com/item/3288...13925173waIb8X
    https://www.aliexpress.com/item/3288...6a725173fPZyib
    The first one looks like my first tube but the spot wasn't that good and it has this terrible graphite connection.
    The second one looks good because they say it has better spot and more able to cut thin metal. (I was able to cut 2mm mild steel with my first tube).
    Does anyone have experience with that kind of tube?
    (by the way steel cutting from my laser )
