From my experience it most have problem on laser tube
I have an older model (2013) rebadged Bodor Mini 5030. The machine was sold to me as a 50W. CO2.
A few weeks ago the UK was hit by extreme weather conditions - 'The Beast From the East' that plummeted the country to well below 0 degrees very quickly. The water in my tube and in the chiller froze solid overnight. The tube was destroyed, I did not think the machine had been damaged in any other way.
The dimensions of the installed tube (1200 x 55mm) lead me to believe it was a 60w tube. I've obtained a new 60w tube, but on installation, and running the coolant through, it will not fire, and shows no signs of life at all.
I'm now looking at the possibility that the PSU has crapped out too. I intend to test the output at the anode and diode with a multimeter but am not entirely what voltage it is meant to be outputting.
I read a suggestion of holding a polystyrene peanut on a cotton thread by the live end to see if it is drawn toward it! Is this really a thing??
So it looks like I'm looking at a faulty tube or a bad PSU. I was hoping someone else might have some insight into the possible problem or useful diagnostics, I really need to isolate the problem so I can take the necessary actions.
Thanks for reading!
Simon
co2 laser tube range from 80w-150w www.cantonwonderlaser.com
